06-20-2020 23:40
06-20-2020 23:40
A"phone restart is required to re enable notifications on your tracker"..
This message comes up often daily and even doing this procedure doesn't always work and when it does only works for a short time then get above message again.
06-21-2020 01:34
06-21-2020 01:34
Hi @Shellus What phone are you using? Have a look at THIS Help Article on troubleshooting Notifications.
Helen | Western Australia
Best Answer07-06-2020 15:44
07-06-2020 15:44
HUAWEI P20 Pro
Best Answer07-06-2020 17:55
07-06-2020 17:55
Thanks for that. There are special instructions for the Huawei P20 Lite model (different to yours, I know, but it might be helpful - see below). If nothing there helps you then you will need to contact Customer Support.
HOW DO I USE THE FITBIT APP ON MY HUAWEI P20 LITE PHONE?
To use the Fitbit app on your Huawei P20 Lite phone, verify the following settings:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
