08-19-2019 07:07
08-19-2019 07:07
Does anyone else have problems getting notifications on their versa? I’ve reset both my phone and versa, notifications are on both the phone and versa, and everything is updated.
08-19-2019 07:34
08-19-2019 07:34
I’m having the same problem. Got an iPhoneX and I don’t get some notifications on my Versa anymore. Still get calls and FaceTime but not texts or emails. Any suggestions?
Best Answer08-19-2019 07:39
08-19-2019 07:39
I’ve got the iPhone 8, I don’t get notifications on anything, calls texts, emails. I’m getting ready to turn my watch in for warranty. I’ve had it almost 8 months now. Good thing I’ve got the extended warranty.
Best Answer08-19-2019 08:38
08-19-2019 08:38
Hi can only tell you how to do it on iPhone go to settings select each app you whant notification select notification are banner locked tempery select all tree then when you recive messages on phone click Fitbit then motivation then app notification toddle on off apps you whant notification from
Best Answer08-19-2019 08:44
08-19-2019 08:44
I just got mine working. I found an article. Hold the bottom on the left side of the face and swipe the face to the left. Another area for notifications should come up. Mine was off, just simply turn it back on.
Hope your problem was as simple as mine. Good luck!
08-19-2019 15:27
08-19-2019 15:27
Hi checked it all notifications under setting on watch are all set to on hi think it as somthink to do with the phone
theres no banner setting in messageing
and no way to change or add another divice for forwarding see pic
Best Answer08-19-2019 18:21
08-19-2019 18:21
Hold the left button on the left side of the Fitbit, while holding the button swipe left across the screen. There are 2 areas for notifications in the versa itself.
Best Answer08-19-2019 18:39
08-19-2019 18:39
In both places there both on and still nogo
