01-17-2019 06:49
01-17-2019 06:49
I have just one text message that has been deleted from my phone but will not delete from my watch. How do I delete it? I have "cleared all", "mark as read", "opened" and "cleared". When I do these steps I get a "Reply failed" message. Any suggestions?
01-17-2019 06:57
01-17-2019 06:57
Same. . . . if you go to settings and "about" choose Shutdown and restart your fitbit. I had one message stuck as well.
01-17-2019 06:57
01-17-2019 06:57
01-17-2019 07:08
01-17-2019 07:08
Yahoo! That worked, its been driving me crazy. Thank you 🙂
01-24-2019 13:32
01-24-2019 13:32
Thank you. That fixed the problem.
03-17-2019 08:09
03-17-2019 08:09
Where is settings on the fitbit site? There is no "about"
Best Answer03-17-2019 08:13
03-17-2019 08:13
Oh fixed it went to settings on watch not fitbit app Oops😀
03-19-2019 10:14
03-19-2019 10:14
@tucsonmom I hope you're doing well! Happy to hear that the restart help you solved the issue with the text message stuck on your Versa. Also thank you for clarifying that the restart was done on the device itself as this may help other members in the same situation.
I'll be around.
Best Answer03-19-2019 17:03
03-19-2019 17:03
Best Answer05-07-2019 06:06
05-07-2019 06:06
This fixes the problem but the issue keeps coming back. I have to start my watch at least 2 or 3 times per week due to this and various other issues. This is clearly a bug. Is there any plan to fix it so that we don't have to keep restarting the watch?
