04-21-2022
20:37
20:02
04-21-2022
20:37
20:02
Does fitbit sell clock faces? I thought I just read that only third party vendors sell faces and therefore I can buy all the faces I want but fitbit doesn't keep this information so that we can retrieve.
04-21-2022 15:51
04-21-2022 15:51
Why is it so hard to find my clock faces? I see the five that I picked to be available when I long press my watch but where are the other ones? Versa 3 is slow and complicating. When you purchase a face it seems as if there was a mistake made then like 5 minutes later you find it.
04-23-2022 04:21
04-23-2022 04:21
Hi @ZellC - the Fitbit clock faces are free.
There are many other good third party ones that are free, try those before actually buying third party ones.
You can only have 5 clock faces stored at a time, and will have to delete at least one in order to be able to load more. There is no history kept of the ones you have removed.
You can search, using criteria, the gallery in the Fitbit App or by Google but bear in mind the ones you see in the Fitbit App are available for your watch whereas Google will return ones that may not be available for you watch, it is normally indicated for which watches they are made.
