Anyone else use a Pixel 3? Mine keeps switching off the Bluetooth so that my watch isn't always syncing.
I never used to have this problem with my Fossil Android watch.
Anyone else experience this?
@Keith1974 Try factory reset. It seems that the bluetooth issues correspond to your recent OS update... ugh ;/
@Keith1974 I am on Pixel 3. What do you mean by switching off bluetooth? Phone bluetooth you mean or disconnecting Versa?
Best Answerw-e-i-r-d... Ok, let's try this:
Let me know how it goes.
Best AnswerSadly this hasn't fixed it. I woke to my Bluetooth being off, switched it on and an hour later it was off again
Best Answer@Keith1974 Let's repeat the steps 1-6 with a little spin:
Best Answer@Keith1974 I know there used to be a bug that would make bluetooth randomly switch off on Pixels but I thought Google resolved it with an update ages ago... Are you running the latest version of Android? Also, did you have this issue before or is it pretty new, let's say after recent OS update? I will be honest, there are two more options to try:
I wish I could help more. ;/
Best Answer@Keith1974 Try factory reset. It seems that the bluetooth issues correspond to your recent OS update... ugh ;/
