The last couple of days my Fitbit Versa is draining quick.
Yesterday after a full charge it was dead by morning (wouldn't turn on)
Today after charging to 75% at 8am it is down to 51% at Noon.
One caveat is that I am using the Fitbit Android Beta, but not sure if it is related as I thought this was just a gui change.
Hi, the only think I can assume is that the beta version uses more battery power of your Versa during syncing. You only can find this out by installing the regular Fitbit app again. But, I do not think that the beta version drains your battery so fast. So, restart your Versa 4-6 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons. If this does not solve your problem, contact Customer Support and ask for a battery test.
