03-29-2022
07:40
20:14
03-29-2022
07:40
20:14
I'm having an issue with my Versa 3 when I have notifications that I can respond to. I have several apps on my android phone that send notifications. The notifications show up on my Versa 3 without any issue. However, if the notification allows a response such as "complete", "skip" etc and I enter one of them the response is never sent back to the application. This worked fine initially went I first set up my Versa 3. Now 3 months later it just stopped working. Any idea on how to fix this would be appreciated.
04-01-2022 12:42 - edited 08-03-2023 12:07
@JoeCam To find more information, see How do I respond to messages with my Fitbit device?
Best Answer03-29-2022 14:51 - edited 12-11-2023 04:08
Hi there, @JoeCam. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with the quick replies feature.
Apps that allow you to reply to a message directly from the notification on your Android phone also support quick replies on your Fitbit device. This includes, but isn’t limited to, apps such as:
For more information, see How do I respond to messages with my Fitbit device?
Also, please make sure that the mobile phone you're using meets the requirements listed here.
Hope that helps.
Best Answer04-01-2022 10:02
04-01-2022 10:02
How do I determine why Fitbit app is not handling replies from my Versa 3 for some apps or if the replies from Versa 3 are never making it back to the app?
