09-20-2019 13:14
09-20-2019 13:14
Hi! I was wondering what the difference is between sleep setting and the do not disturb setting? (After update). Thanks !
09-20-2019 13:57
09-20-2019 13:57
See Quick settings.
Looks like sleep mode adds a few more "darkness" items to 'do not disturb':
Quick settings
Adjust notification and display settings. Swipe down from the top of the screen, and tap the quick settings icon
| Do Not Disturb | When you turn on the do not disturb setting:
| Sleep Mode | When you turn on the sleep mode setting: Notifications don't cause the watch to vibrate or the screen to turn on.
You can't turn on Do Not Disturb and Sleep Mode at the same time. |
Best Answer09-24-2019 06:11
09-24-2019 06:11
After the last update my original Vera will not share notifications. I can barely keep it connected to Bluetooth. I have all the right settings to share notifications. My quick settings on the phone are off. I'm losing my mind here. I saw your reply to the above and hoped you might have some insight into what is going on.
Thanks!!
Best Answer11-06-2019 03:09
11-06-2019 03:09
I have had absolutely nothing but issues since the latest up. My watch freaks out and either flips back and forth between quick settings and the home face or just locks on the quick settings face.
