10-14-2019 15:38 - edited 10-14-2019 16:15
I am unable to tap the rematch button after a challenge completes. When swiping the results, the screen will not stop in the middle it either slides up above the top of the screen or slides down below the bottom of the screen. I am using the latest Fitbit OS on a Samsung Galaxy S8 with Android 9.
The problem appears to be that there is way too much space between the last contestant and the rematch button.
10-14-2019 16:08
10-14-2019 16:08
Hi @bbran , try restarting your Versa several times in a row with the two button method: press and the left and right lower buttons together untill you see the Fitbit logo and release the buttons. See if that solves your problem. Regards kuzibri
Best Answer10-15-2019 09:57
10-15-2019 09:57
The problem appears in the Android app, not on the watch
