05-26-2020 12:01
05-26-2020 12:01
How do I remove a clockface I no longer want?
05-26-2020 13:47
05-26-2020 13:47
Hi @SunsetRunner
Are you referring to the "My Clock Faces" showing on the bottom of the Clocks, My Versa 2 screen? If so, tap on the clock face you want to remove from the "My Clock Faces", then tap "Remove Clock Face" on the bottom of the screen.
I hope this helps 😊
08-27-2020 13:53
08-27-2020 13:53
I do this and I want to remove the last clockface since the default always on analog ckockface is the one I want to always show (I really don't like having to move my wrist to get a shiny different clockface with a lag of almost a second).
However I seem to be able to remove it, then it comes back without error notice. Just pretends it did not just fail to do what I asked.
