08-09-2020
11:04
15:24
EdsonFitbit
08-09-2020
11:04
15:24
EdsonFitbit
All of a sudden my restoration data disappeared. Deleted app, turned off and then on Bluetooth - powered off phone. All other sleep data shows and when I go to my Sleep data it does show the %’s but when I go in the click on graph...nothing there. Anyone having same issue and do you have a fix?
08-09-2020 12:00
08-09-2020 12:00
@Tlniede Many users are reporting the same problem. It seems to have started with an app update. Fitbit is aware.
Laurie | Maryland
Best Answer08-09-2020 15:34
08-09-2020 15:34
Thank you so much! Are you aware of a fix?
Best Answer04-08-2021 03:51
04-08-2021 03:51
Good morning, did you ever get an answer of how to get your restoration data back? I just bought the charge three about six months ago and it’s hard to get information on - it it’s like they sold me an obsolete Fitbit 😩
05:22
15:28
EdsonFitbit
04-08-2021
05:22
15:28
EdsonFitbit
So funny you should ask. I did get it back for a few months and now it is gone again. Very frustrating. The answer I got was that they were working on it.
Will be reaching out again. I pay for the premium because of that data.
I do love my FB. It works a lot more often that it doesn’t
04-08-2021 15:24
04-08-2021 15:24
Thank you for visiting the Fitbit Community, @Tlniede @CHAPPY0911.
Thanks for letting us know about this issue with restoration stats missing in the Fitbit app. Our team is currently working to resolve it and hope to have a fix soon. Please be sure to keep your Fitbit devices and app up-to-date to ensure you receive the quickest resolution.
We're sorry for any trouble this situation could have caused. We appreciate your patience and look forward to getting you back on track.
Thanks for your support, @LZeeW.
See you around.
Best Answer04-10-2021 09:12
04-10-2021 09:12
Yes same here it suddenly disappeared but the stats are there
Best Answer04-10-2021 12:43
04-10-2021 12:43
I have this issue when using the fitbit app on my iPad Pro. However, when I look at the same data using my iPhone XS Max, the restoration heart rate graph appears properly!
Best Answer04-11-2021 09:37
04-11-2021 09:37
This has recently happened to me. All restoration history had gone. Any suggestions on how to fix?
Best Answer04-11-2021 15:10
04-11-2021 15:10
Thanks for your comments, @Lucia2021 @Richinseattle @ChelleMiChelle.
At the moment, there is no workaround to resolve this issue. Once any update be available it will be communicated as soon as possible.
If you have any question, please let us know.
