06-09-2020 17:51
06-09-2020 17:51
I'm having trouble restoring the original clock face to my Fitbit Versa 2. What should I do?
06-10-2020 09:32
06-10-2020 09:32
What is not happening, do you get any errors?
If you have only had 5 or less faces, you simply only need to switch faces on the watch which will store the last five faces.
06-10-2020 09:32
06-10-2020 09:32
12-29-2022 11:15
12-29-2022 11:15
One of my five clock choice's ("Photo Goal") will no longer load. When selected the screen is now blank. How can I restore?
Best Answer12-29-2022 11:43
12-29-2022 11:43
@JazzyM I searched the Gallery for your clock face. The one I found is a third party clock face. Normally, I would recommend deleting it then reinstalling it. But it’s a paid clock face and I don’t know if deleting it is permanent.
You might need to contact the developer for help.
You also added on to an older thread about a different issue. If you need more help, please start a new thread in the App Gallery forum. That forum is a better fit for your issue.
Laurie | Maryland
Best Answer12-29-2022 12:56
12-29-2022 12:56
