05-16-2019 13:31
05-16-2019 13:31
Hello;
I was wondering how delicate is the fitbit versa screen? Do I need to use a screen protector on it.... does anyone use/not use one and have experienced scratching or cracking of screen?
Thank you;
Heidi
05-16-2019 14:15
05-16-2019 14:15
Hi, cracking Versa screens have been mentioned before, so if you're worried about that, use a screen protector. Look at Amazon regarding this. Personally I do not have any problem with the screen at all untill now without a screen protector. But, I take good care of my Versa and do not wear it in extreme conditions. In normal situations I wear it 24/7.
01-17-2020 17:04
01-17-2020 17:04
My daughter got her Versa 2 for Christmas, 2 weeks later she fell and was completely unharmed by the fall, but the screen on the device is completely destroyed. So I would say that durability is pretty weak. I contacted Fitbit and the warranty does not cover the screen, so nothing can be done.
08-12-2022 15:36
08-12-2022 15:36
My friend has a Versa 2, and he uses it like a 'normal' person (Not 100% carefull, but also not crazy) and after 1 month you could see light damage (some scars),
But after 10 months it was totaly ruined (scars + cracks).
Fitbit says their devices should last 1 - 2 years, and thats not even 50%. So I'd rather get a screen saver.
