04-03-2019 06:05 - edited 04-03-2019 22:57
Hi,
I just bought a Fit*bit Versa but can not connect it to my Samsung Galaxy 8s.
It is as if there is no blue-tooth ...at least it does not show up.
I have restarted...reset ...rebooted ...several times. I have even tried to install it on another android phone...
Any suggestions on what I can try next?
Thanks
04-03-2019 17:16
04-03-2019 17:16
Hello @LoneBee are you using three Fitbit app to setup your Versa?
You should have no problems I'd following the setup procedure.
If it failed please let us know at what step the failure occurs and if you receive any error.
04-03-2019 11:17
04-03-2019 11:17
Hi, your device is supported by Fitbit, so that should not be the problem. Maybe my little guide I wrote regarding updating to the new Firmware version, which you also will get , might be helpfull. It uses WiFi instead of BT. See: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... Good luck and if it's really helpfull for uou, see my signature ![]()
Best Answer04-03-2019 17:16
04-03-2019 17:16
04-03-2019 22:56
04-03-2019 22:56
Thank you @Rich_Laue and @SunsetRunner .
I have now managed to set up my new versa ....I do not know what helped 🙂
I kept trying and suddenly my watch could see the versa.
Thank you for your suggestions!
Have a great day
07-17-2020 09:09
07-17-2020 09:09
have tried 4 different versas and not will connect. The Ionic connects fine. The versa failed when it is "Searching" for the versa. Please Help. Frustrating.
