10-18-2019 19:46
10-18-2019 19:46
I can't always remember to turn sleep mode on at night and off in the morning. Can I schedule a time range where I am usually asleep? My wife loves when sleep mode is on so she isn't blinded by my versa when I flop my arm around in the night. So it is a nice feature. Just needs some automation.
10-18-2019 22:32
10-18-2019 22:32
Hi @dagent23, good to see you in the community.
Swipe to the settings app on your Versa/2 - scroll down to sleep mode (tap it) - scroll down to schedule and tap on customise. You will be able to set a start and finish time in here.
Hope this helps.
10-18-2019 22:32
10-18-2019 22:32
Hope this helps.
10-20-2019 19:32
10-20-2019 19:32
Excellent answer. Thank you!
Best Answer10-31-2019 09:56
10-31-2019 09:56
Awesome! I've had the same question for several months myself. This helps a ton. Just hope they add some more features to the schedule now...like weekdays vs weekends. 😎
01-06-2020 17:46
01-06-2020 17:46
Mi e only had off and on with my versa 2 and now it won't go off sleep mode. Can't get notifications or anything now.
04-29-2020 05:42
04-29-2020 05:42
I set sleep mode with an on and off time but last night the screen came on quite brightly during my sleep time. This morning during my awake hours II checked the sleep mode setting and it was off. My question is, when you've set a range of time for sleep but you are during the NON-sleep mode time, should the setting show as on or off? I'd think sleep mode should always show ON because you've set times but maybe it's designed to show OFF during the awake hours. Can you explain that piece so I know if I've set it correctly? Thanks
09-29-2020 05:58
09-29-2020 05:58
I have sleep schedule set and it works fine at night, but in the morning it does not turn back on by itself. How do I fix this?
