04-29-2018 18:10
04-29-2018 18:10
Is there a way to adjust the brightness on the Versa? I'd like it a little brighter at night.
04-15-2019 08:21
04-15-2019 08:21
Swipe left on your screen to the apps until you come to the “settings” app which gives you the touch option of normal, max, auto and dim. If you touch and hold the app you can move it to the furthest left top or bottom and then you can control it accordingly by using the external top or bottom right button on your Versa watch.
04-15-2019 08:25
04-15-2019 08:25
Best Answer08-12-2019 08:34
08-12-2019 08:34
same here. Can’t adjust settings and can’t see clock or anything on the versa life when outside in bright light. I tried fro
watch. Online. And mobile device. So frustrating
Best Answer10-15-2019 11:29
10-15-2019 11:29
I've noticed my brightness has also dimmed an when I go to adjust, my "Brightness" is grayed out and won't let me adjust....??????? BTW a reset didn't help.
Best Answer10-15-2019 19:10
10-15-2019 19:10
Have you checked your night mode? When I turned on the night mode on my watch, the brightness is grayed out.
10-15-2019 20:10
10-15-2019 20:10
YES Mihsan! I was in "sleep mode". ( I don't know how it got there, but it was!) Thanks!
Best Answer12-20-2019 03:25
12-20-2019 03:25
I tried these steps and it still won't change brightness.
Best Answer12-20-2019 06:28
12-20-2019 06:28
When I go to Settings then brightness, it won’t respond to my tapping it. I can’t scroll down either. It’s just there and won’t work. It’s set to Dim now, which I must have touched inadvertently and now it’s Stuck! Is there a way to restart?
12-20-2019 14:08
12-20-2019 14:08
Best Answer12-23-2019 10:20
12-23-2019 10:20
The same thing is happening to me and I can barely see my fitbit
Best Answer12-23-2019 11:38
12-23-2019 11:38
12-23-2019 11:57
12-23-2019 11:57
Oh wow! Thank you so much for answering! I'm calling them now!
Best Answer12-29-2019 19:53
12-29-2019 19:53
I read through these and what helped me was turning sleep mode off
Hope this helps
Potatoesan dafries
Best Answer12-29-2019 19:56
12-29-2019 19:56
Swipe down, then in the top left look for the quick settings button. Click on that, then in the middle of the bottom row, there is a sun or brightness picture. Click on that to adjust the brightness.
Best Answer12-29-2019 22:06
12-29-2019 22:06
It doesent work if you havent updated it though and you need to turn sleep / night mode off
12-30-2019 06:49
12-30-2019 06:49
Best Answer01-06-2020 19:53
01-06-2020 19:53
Where is the dim button please to make it brighter as screen is very dim. I have found a Dim setting in settings but It won’t let me change it
Best Answer02-23-2020 06:14
02-23-2020 06:14
This did not work. I can go to settings and to brightness but it is grayed out so I can’t select it. What now?
Best Answer03-11-2020 01:00
03-11-2020 01:00
THIS IS ONLY HELPFUL IF YOU HAVE UPDATED YOUR FITBIT VERSA
you have to turn it off sleep mode, you can find this is you swipe DOWN on your screen then it will open a notification bar, swipe down again and it will have 2 icons, click on the one with the two lines with dots on the end, it will have a picture of a moon, click that if it is blue. or. go into settings and scroll to sleep mode click the section that says 'sleep mode'
hope this helps!
chicken bannana drumstick
