Screen dims - Temp?
I've had a Versa for over one year without this problem, but yesterday as soon as I stepped outside, my screen dimmed to almost unreadable  levels. The temperature drop was modest (from 70 degrees F indoors to 50 degrees F outdoors). The problem persisted for more than 2 hours while I walked outdoors.  When I re-entered my house the screen immediately lit up to normal brightness..
I have to conclude that the temperature drop influenced my screen brightness. I note that I have used this Versa for more than one year, when much lower winter temps were encountered with no screen dimming.
I could not find any posts that correlated low temps to screen displays, so I just post this FYI.
2 REPLIES 2
Your brightness is setup to Auto.
Set it to normal and it will stay bright all the time
Mine is doing the same thing.. but i also think the screen is dying slowly or the watch has the watch has slowed down and the screen is starting to respond slowly
Anyway.. to set the birghtness .. go into setting in your watch and find brightness and set to normal
Thanks. That fixed it.
