Screen protector Versa
Has anyone heard of or purchased from Amazon this: Case for Fitbit Versa, iHYQ TPU Plated Screen Protector Rugged Cover ? Is it worth it?
3 REPLIES 3
@Annsy I do not have that particular one as i find shell cases a bit bulky and rigid, but am using this one instead. I did have a shell type case, but found it to be problematic as droplets of water/moisture tended to accumulate under it.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
Thanks. I have this too. After a short hike this weekend, which I don't
remember bumping into anything and didn't fall, I found small shattered
piece of the glass just below this protective cover near the frame.
@Annsy Ouch 😔 In that case you might wanna go with the shell case indeed. I noticed Versa is prone to marks on the edges. Mine has a 2 mm scuff in the metal part. 😔
