08-07-2019 05:32
08-07-2019 05:32
Yesterday my Fitbit just starting showing the logo, I've read other topic on this I charged it and tried to factory reset it and it never vibrates the screen just goes black then a few seconds later the logo comes back. I've only had this for 10 months, any other suggestions?
08-07-2019 05:46
08-07-2019 05:46
Is the screen with the logo the one it showed when you first got it (with the URL www.fitbit.com/setup) ?
If so, it means that it is no longer connected to your account for some reason and you'll need to go through the setup process again to reconnect it. In the account section of the app select "set up a device"
10-01-2019 05:03
10-01-2019 05:03
I am having a similar problem.My Versa started showing only the logo.I tried resetting according to the instructions given in some other answers but the screen just went blank and started showing the logo again in a couple of seconds.Then I just left the watch as it is.After a day i noticed that it had got discharged.So i tried to charge it.While charging,the screen was back to normal.Relieved,I charged it to 100% and wore it to work.It was working perfectly normal.After about 3 hours,it started showing the logo again.And it got discharged in about a day(usually lasts 3 days with continuous use).It was showing just the logo continuously.I again charged it and it started working as normal but the problem relapsed after an hour.Please advise ASAP.
Best Answer10-01-2019 05:13
10-01-2019 05:13
Best Answer10-01-2019 05:31
10-01-2019 05:31
Best Answer10-01-2019 05:49
10-01-2019 05:49
