06-17-2018
10:27
13:12
AndreaFitbit
06-17-2018
10:27
13:12
AndreaFitbit
Just finished setting up my new Versa but can’t figure out how to set up the weather. Used an iPhone and Fitbit mobile to set up. Where is this located?
Moderator edit: format and label.
06-17-2018 10:36 - edited 06-17-2018 11:18
On the App Dashboard, click on the Account Icon at the upper right and then Versa and then Apps and then Weather.
06-17-2018 11:28
06-17-2018 11:28
Perfect. It worked just fine! Thsnks🙂
06-17-2018 19:00
06-17-2018 19:00
Anyone knows if the weather app uses alot of mobile data?
Best Answer12-15-2018 17:17
12-15-2018 17:17
Thanks. But when I click on "Applications" in my "User Profile", there are no applications shown?
Best Answer12-29-2018 22:33
12-29-2018 22:33
Thanks. Weather seems to be working, but is reading temperature in Celsius vs Fahrenheit. Also when I click on "Applications" in my "User Profile", there are no applications shown (including weather)?
Best Answer12-29-2018 23:44
12-29-2018 23:44
@Yuman Are you following the following steps to your applications: click on the Versa icon >> apps >> weather? Because if you do you will see an option to change units between Celsius and Fahrenheit. If you have already set up your weather then you will have to click "settings" within the weather tab to change the unit. I hope this is helpful.
Best Answer12-30-2018 17:50
12-30-2018 17:50
Best Answer01-02-2019 07:25
01-02-2019 07:25
Make sure you are selecting all apps and not my apps at the top
Best Answer01-22-2019 08:37
01-22-2019 08:37
My weather app is no longer working, not able to get it to load again after following the directions. Really getting frustrated at this point, should be a simple fix, since it was working before. Any help would be appreciated!!!!
Best Answer02-06-2019 11:45
02-06-2019 11:45
I have the same issue!
Best Answer02-06-2019 14:25
02-06-2019 14:25
Best Answer09-03-2020 03:19
09-03-2020 03:19
As already said go to the Apps Dashboard on the phone app and select the weather. To get it to work you need to put in a city (maximum of 2) then it works fine.😈
Best Answer09-03-2020 03:22
09-03-2020 03:22
It's not in the user profile it's in the watch profile which is just above "Set Up A Device" just click on the watch si=and your off to go 😈
Best Answer09-03-2020 03:23
09-03-2020 03:23
Yes😈
