07-27-2023
17:08
06:43
EstuardoFitbit
07-27-2023
17:08
06:43
EstuardoFitbit
I can’t use my side button on not even 1 yr old versa 2 . Now deemed useless as I only bought it for the functions it had .
Moderator Edit: Clarified Subject
07-28-2023 06:46
07-28-2023 06:46
Hi there @Flynny83. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa.
I recommend trying to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
Once you've done that, please restart your Versa by following these steps How do I restart my Fitbit device?
Best Answer07-28-2023 14:12
07-28-2023 14:12
07-30-2023 07:18
07-30-2023 07:18
Thanks @Flynny83 for your reply.
Since the button seems to be damaged, I'm going to request a case for you with our support team. This issue needs to be reviewed for them to determine your warranty status. Please keep in mind that they are going to reach out to you via email. Keep an eye on your inbox to be aware of what their instructions are.
