12-30-2018 03:43
12-30-2018 03:43
Hello,
I got a Versa at Christmas and my sleep data are showing on the Fitbit app but not on the device itself. (On the device, there are blanks against the various sleep parameters.)
The instruction manual suggests sleep data should show up on the device, but I've seen comments online saying that this feature is not yet available.
Can someone please advise?
Thanks, Roger
12-30-2018 14:47
12-30-2018 14:47
@london2000 No , it should show if the sleep has been tracked and synced. Try rebooting Versa by pressing and holding the left and bottom right buttons until Fitbit logo flashes, then syncing again.
Best Answer12-30-2018 16:38
12-30-2018 16:38
I'm having the same problem. Sleep data appears on the Fitbit app, but in the Today app it just shows dashes, like this:
- -h - -m
asleep
Best Answer12-30-2018 19:32
12-30-2018 19:32
@JoeSchwartz Have you tried rebooting your tracker?
Best Answer12-30-2018 21:25
12-30-2018 21:25
@MarrrmadukeYes, several times with no effect.
12-30-2018 21:32
12-30-2018 21:32
@JoeSchwartz If you go to your Fitbit mobile app, to Versa's apps, is there an update to Today app? If you open the Today app page in Fitbit mobile app, what's the release date of app? Also, please make sure you're running the latest version of the fitbit mobile app.
Best Answer12-30-2018 22:22
12-30-2018 22:22
@Marrrmaduke The Fitbit app doesn't show any update to the Today app. It says the Today app is version 33.1.30.c, updated on December 19, 2018. I'm using version 2.39.1779 (60070) of the Fitbit app for Windows 10, which appears to be the latest version according to this page:
https://help.fitbit.com/articles/en_US/Help_article/2025/#windows
Best Answer12-30-2018 22:56
12-30-2018 22:56
@JoeSchwartz It seems to me like it's a bug in the app. Versa is not pulling back the data after calculation of sleep stages from Fitbit mobile app, but it's not the connection fault. You can try uninstalling and reinstalling Fitbit Win10 app as this may prompt refreshing of the Today app on your Versa. The apps are first loaded within Fitbit app and only during sync installed on Versa. Place your Versa in the charger while doing that (for a few hours). The bottom line is Today app needs an update. In my case, though I'm on Android, sleep works, but I cannot log water. It worked for a while than it stopped. Actually the + sign disappeared entirely from Today app.
Best Answer12-31-2018 00:28
12-31-2018 00:28
Thanks for the feedback provided so far. If I've correctly understood it, then this link
(Add sleep to "Fitbit Today" on the Ionic/Versa) suggests that the Versa doesn't currently show sleep on the device itself, only on the phone app. This seems very strange, and contradicts the instruction manual.
I'm using the Android app, which is up to date. Rebooting hasn't helped.
12-31-2018 00:39
12-31-2018 00:39
@london2000The sleep stats were added to the Today app with Fitbit OS 3.0, which was just released a couple weeks ago: https://help.fitbit.com/articles/en_US/Help_article/2302
Best Answer12-31-2018 01:11
12-31-2018 01:11
@JoeSchwartz I think my Versa is up to date as it was only set up for the first time less than a week ago. It is running Firmware version 32.331.30 and the Android app on my phone is up to date.
Best Answer01-01-2019 08:34
01-01-2019 08:34
@london2000 wrote:Thanks for the feedback provided so far. If I've correctly understood it, then this link
I am seeing last night's sleep total, then the next screen shows the breakdown and the next the average for the week on my Versa.
Best Answer01-01-2019 17:39
01-02-2019 01:35
01-02-2019 01:35
@Marrrmaduke Bizarrely, whereas before I wasn't seeing any sleep data on my Versa, I'm now finding that it appears after I've been awake for an hour or so! It is, though, visible on my phone from the moment I wake up.
It all seems very strange but I think I just have to live with it and perhaps the bug will eventually get sorted out.
I appreciate the help you've given.
Best Answer01-02-2019 19:41
01-02-2019 19:41
@london2000 I'm glad it works though with a delay. 😄
01-14-2019 03:16
01-14-2019 03:16
Hello,
i have the same issue, sleep data on the Fitbit app but not on the device.
Today's app is update and i still not see my sleep data on the device and i can't add water on the device also (not even listed in settings)
Best Answer01-14-2019 11:58
01-14-2019 11:58
@lapincube today app is ... Buggy... At least for some. Uninstall and reinstall Fitbit app, go to Today app in the Apps in the Fitbit mobile app and check for updates, install if there's an update, sync, place your Versa in the charging dock for a few hours. Today app should get updated.
Best Answer01-14-2019 12:19
01-14-2019 12:19
@Marrrmadukethanks but i just try and no change. Today's app is installed with version 33.1.30.c (20181220).
Edit : settings change is Today's, i have now weight, water intake, and badges but sleep is not listed anymore !
Best Answer01-14-2019 12:21
01-14-2019 12:48
01-14-2019 12:48
@lapincube yes, it takes a while for it to update fully. Glad it is working! 😊
