02-18-2019 06:05
02-18-2019 06:05
Hi, I just recently got a Versa Fitbit and it isn’t tracking my sleep like my Alta used to. It only tracks the last few hours or the first few hours or maybe a few in between. How do I fix this?
Thanks!
03-02-2019 09:15
03-02-2019 09:15
@Memesheehan I'm glad you're getting new Versa! Yay! 😄
02-18-2019 16:05
02-18-2019 16:05
@Memesheehan Do you have any sleep presets enabled, e.g. bedtimes? Please clear them as they're known to cause such issues. Also, please reboot your device several times by pressing and holding the left and bottom right buttons until fitbit logo appears.
02-19-2019 09:19
02-19-2019 09:19
Thanks I’ll try that!
02-19-2019 11:46
02-19-2019 11:46
@Memesheehan Please do and report back. 😄
02-20-2019 04:28
02-20-2019 04:28
Hi I tried your solution and it did not work... watch said I slept from 3:45- 6-45 totally incorrect. I’m ready to send this thing back and start using my Alta again. ☹️
02-20-2019 11:24
02-20-2019 11:24
@Memesheehan Could you please attach some pictures so I can take a look? All of these can be taken from the Fitbit mobile app:
03-01-2019 10:24
03-01-2019 10:24
@Memesheehan Did you manage to resolve the issue?
03-02-2019 08:07
03-02-2019 08:07
Yes I finally called Fitbit. They are sending me a replacement. Let’s see if this one works or else they can have it back and I will go back to my Alta HR that works just fine. The Versa was a gift. Thanks for all your help!
03-02-2019 09:15
03-02-2019 09:15
03-03-2019 05:51
03-03-2019 05:51
Thanks for trying to help me!!
03-03-2019 09:12
03-03-2019 09:12
@Memesheehan Always! 😄 We are a friendly bunch here. 😄 If you have any questions, just ask. 😄
03-03-2019 10:58
