10-27-2023 07:31
10-27-2023 07:31
Ever since the new app launched sleep tracking has not worked well. It tracks until one of my nightly wake up moments - usually around 3 AM - then just stops tracking, even though I go back to sleep for several hours. I’ve rebooted both phone and watch, pay careful attention to snugness of the band, and keep the contacts clean. Anyone else experiencing this?
10-27-2023 11:16
10-27-2023 11:16
Hi, yes my Versa 3 has no sleep score today. First time it’s happened - watch battery fine, reset the watch, turned Bluetooth off and on again and closed and reopened the app - to no avail sadly. Hoping it will work overnight tonight.
10-29-2023 01:26
10-29-2023 01:26
10-29-2023 07:29
10-29-2023 07:29
My Versa 4 is doing the same thing. I’ve had it only since September. It was recording throughout the night, but then started data gaps about every night. 1-3 hours of missing sleep and heart data, from some time around 3-6am. These gaps affect all the stats. I’ve restarted, adjusted the band to looser or tighter, changed to a more flexible band, and changed clock faces. I didn’t have this issue with previous Fitbit devices.
10-31-2023 06:22
10-31-2023 06:22
Same thing here.Its happened two nights (Sat night & then Mon night). Never had this happen before so i suspect problem is due to a recent update or system change
10-31-2023 14:18
10-31-2023 14:18
Replying to all those who mentioned a similar problem with the sleep tracker. I spoke with the Fitbit help folks yesterday. They did acknowledge - when I asked - that they've been fixing a lot of bugs since the new app was launched. I was walked through the process to do a factory reset AFTER turning off the heart monitor, and them turning that back on after the reset. I also rebooted my phone for good measure. Unfortunately this did not solve my problem so I'll have another chat today. But perhaps this will work for others! Good luck!
11-05-2023 20:06
11-05-2023 20:06
I doubt anything will work. That update has been nothing but trouble and Fitbit is determined to lose customers because it refuses to go back to a reliable and working system. Development has reversed at Fitbit apparently.
11-05-2023 20:20
11-05-2023 20:20
11-06-2023 00:53
11-06-2023 00:53
Exactly the same for me too. Three nights of recording all data. So glad to see it working again! Fingers crossed that it continues.
Best Answer11-10-2023 13:59
11-10-2023 13:59
I’m still having intermittent issues. A complete night, then a night or 2 with gaps. I called tech support 2 days ago and was walked through the steps of restart, reset, reload etc and still had gaps of early morning hours that night and the next. (And on 2 of my last 3 runs, heart rate tracking stopped, so very low zone minutes, and the device exited the run tracking.)
So I was surprised that last night I had full heart rate and sleep tracking.
11-11-2023 08:03
11-11-2023 08:03
I managed four nights then it went again unfortunately. But like you last night I got a full night of data again! Out of the blue. I was wondering today if if was a bandwidth issue! Too many people needing downloaded data or synced data at the same time, maybe it’s restricting who gets it when!!!!
Best Answer11-11-2023 08:35
11-11-2023 08:35
11-11-2023 08:51 - edited 11-11-2023 08:53
Agree. I’m wondering how long I give it as a fair chance to fix the issue. My hopes are raised every time it works. But disappointment soon follows. I just want what I had back. I liked everything as it was before. It worked 100 percent. If that’s gone for good then unfortunately I’m probably going to have to switch too ….. unless there’s a statement from Google/Fitbit with some acknowledgment and timelines. Let’s see. Positive thoughts that everything will work soon.
11-11-2023 17:39
11-11-2023 17:39
I have the same problem with sleep stages with my second versa three unit should have been updated to the latest but unfortunately it’s not doing its job. My wife has a smart watch by Apple and she does not have any type of problems like this let’s get this fitbit problem fixed once, and for all.
11-11-2023 17:54
11-11-2023 17:54
I have the same problem. No more Fitbit products for me.
