07-02-2022 09:50
07-02-2022 09:50
I've just replaced my broken Versa 2 with a new Versa 2, I've been using the Sp02 clock face on the old one but when I try to download it on the new Versa it says that it's not compatible - any suggestions?
Thanks
07-02-2022 10:28
07-02-2022 10:28
Hello @jspace and welcome to the Community. If you just added your device to your account, this will explain things. Your new device has the firmware from when it was manufactured. You need the current firmware to get certain apps and clock faces. Fitbit is always sending out firmware updates to newly activated devices. You got in line when you activated. You should get the firmware updates in 24-48 hours.
Laurie | Maryland
07-02-2022 10:28
07-02-2022 10:28
Laurie | Maryland
07-03-2022 02:58
07-03-2022 02:58
Ok, That makes sense. Thanks! 24Hrs to go...
08-10-2022 11:19
08-10-2022 11:19
Same problem today with my new replacement. They told me to wait a week and try again when I called customer service.
08-10-2022 15:06
08-10-2022 15:06
My update came through in around a day and a half in the end, so not too long of a wait - fingers crossed for you, hopefully it won't be too long!
The versa did an update straight out of the box, so you'd think they could push the latest firmware at that point - unfortunately it doesn't seem to work that way 😞
