09-01-2022 03:37
09-01-2022 03:37
Hello,
I initially acquired my Versa 2 Standard Edition on July the 12th '22.
I have used it mainly for everyday routines/life. I take it off when showering. However, I've used it a couple of times this summer when swimming at the beach (up to an hour or so).
My FitBit home button has been stuck for a week now. It is not working. Rice 'absorption' and toothpick cleaning haven't helped. Also, trying to clear debris using canned air hasn't worked out well.
This is a relatively new product. Since it is under warranty, which options do I have left?
Thank you,
OGR.
09-01-2022 05:22
09-01-2022 05:22
You might also try rubbing alcohol, which is also recommended for cleaning. If the button is still stuck, as it is under warranty and you have tried recommended cleaning procedures I would suggest getting in touch with Fitbit Customer Support on Contact.Fitbit.com .
09-01-2022 05:22
09-01-2022 05:22
09-01-2022 09:24
09-01-2022 09:24
Thanks for your reply, Julia. Unfortunately, the trick hasn't worked for me but I have contacted Customer Support to receive a replacement.
