01-03-2023 03:19
01-03-2023 03:19
How do I change the order of stats when I swipe up? It used to show steps first, now it shows sleep first
01-06-2023 12:49
01-06-2023 12:49
swipe right tap on exercise then the gear icon and scroll down to customized stats and press top stat until it show steps about 11 taps same goes for the middle and bottom stats as well hope that helps 😁
19:51
08:06
01-06-2023
19:51
08:06
Hi @Tabette - when you swipe up each stat is a tile which if you press and hold, can be moved.
At the bottom there is Settings which you can use to turn them on and off.
If you turn them all off and turn them on one by one they should come in the order you turn them on. But you have to exit Settings after turning each one on and select it again for the next one.
