07-20-2022
12:21
17:47
07-20-2022
12:21
17:47
I got my Fitbit at Christmas and I love it, but there is one problem, the strap is causing blisters/sore areas on my wrist. This is not happening under the watch part but on the same side as my palm. It can get so sore I have to take it off and it then causes areas where my skin peels off.
07-20-2022 15:18
07-20-2022 15:18
Fitbit recommends that you take the watch off one in a while or if it gets wet. But if it still continues, try getting a different material strap like vegan leather or fabric.
Best Answer07-20-2022 15:22
07-20-2022 15:22
I do take it off regularly, but it still happens. I think there is something up with Fitbit’s straps if they are causing this reaction on my arm.
Best Answer07-20-2022 20:43
07-20-2022 20:43
Your skin might be allergic to the material that the strap is made from so try buying a different material strap like vegan leather or fabric.
Best Answer07-20-2022 20:44
07-20-2022 20:44
Also, have you washed your Fitbit strap recently?
