When you say youu record a run @Littlebee79. are you recording the run with the versa and using GPS?
With the next sync, if Attacks is conected to your Fitbit account then this run should be sent to Area a.?
Has Strava received the run?
If so, then the Strava app on the Versa should be able to the data from your Strava account?
So my question is how much of the above happening?
