03-25-2019
19:18
07:17
LanuzaFitbit
03-25-2019
19:18
07:17
LanuzaFitbit
While I swim, I can track my lengths. However, I am not able to get out of the swim page on my Versa and the data will not sync with my phone.
Moderator edit: Added label
Hello @Laboj.
Thanks for bringing this up! Let me help you figure out what is going on.
I will be moving this thread to the Versa board as I think it is better suited for it.
I'd like to recommend that you try restarting your Versa before you swim. That should guarantee that it will work as intended.
In the meantime I'd like to ask you to provide more details on what is going on. Please by as specific as possible. Does the Fitbit get stuck and will not respond at all or what is it exactly that happens?
Look forward to your reply.
Hello @Laboj.
Thanks for bringing this up and trying the restart.
In this case I'd like to ask if the situation has improved since the restart or if it has continued.
In the meantime I'd like to ask you to share some screenshots of the information that you mentioned is showing on the exercise page. It could be that after the restart starts being more accurate.
Let me know if you have any further questions.
Best AnswerMy new Versa is still working and initially tracked my swimming. Hiever, I swam 3 different days this week. My Versa tracked the activity, but did not track it as exercise nor swimming. I have restarted the Versa three times but neither ever shows up. I also checked my settings and everything seems like it should work, but it doesn't. I am very frustrated. Suggestions?
Best AnswerI have exactly the same problem with my Versa when I swim laps. I can start it, and the laps seem to be logging, but I cannot stop the tracking. When I finally get it to stop by pressing back button and bottom right button, the laps do not show up on my log on the app. I am on my second Versa. Both devices did this.
Welcome to the Forums @SDJamie. Hello @Laboj.
Thanks for sharing those details and letting me know that you are both on your second Versa.
@Laboj Are you referring to tracking automatically? In that case maybe you could try to manually start the swim tracking to make sure that it is properly tracked.
Do keep in mind that the strokes that you practice can factor into the automatic tracking. Are you switching strokes as you swim or are you being consistent in that regard.
@SDJamie, how is it not letting you stop the tracking? Could you go a bit more in-depth in to that? Could you share more details on that? I'd like to take a closer look.
Let me know if there are any other questions.
Hello @Laboj.
Thank you very much for that quick reply and for sharing those details on the situation.
In that case, I'd like to recommend that you restart you Fitbit right before going to swim. That should help so that it has an easier time tracking the swims.
Keep me posted on how it goes with restarts.
Thanks for that clarification both of you!
@SDJamie and @Laboj, could you both try to do a restart before going to swim and running the activity manually like this again? I'd like to know if the restart allows the activity to be paused. In addition to that, if it won't pause, try slightly drying your finger to make sure that it is not water on your finger that could be preventing the screen from recognizing touch.
Please keep me posted on how it goes or if there are any other questions.
Best AnswerHi. Just remember to push the button and not the screen. I was making this mistake after migrating from the BLAZE.
Hello @Laboj and @Anointedrj.
@Anointedrj Thanks for jumping in to help!
@Laboj They are referring to pressing the button on the side of the Fitbit that corresponds to the pause button. If you press the button that is next to the pause button it will pause the activity too.
Hello @Laboj.
Thanks you quick reply.
That would be correct! I worded it that way because it applies to other buttons that might show up on the screen.
As always, let me know if there is anything else I can help you with.
