08-10-2020 08:19
08-10-2020 08:19
I have been having problems syncing the Versa II after I finally did the firmware update last week.
I am syncing with a Samsung tablet. It had worked well until a few days ago.
The problem is "device not found" when I launch the fitbit app.
If I restart the Versa II then sync works.
Annoying.
08-10-2020 13:37
08-10-2020 13:37
Consider yourself lucky yours will sync after turning it off and back on. Mine hasn’t sync’d properly since the new update and not at all since Saturday no matter what I try. To top it all off, the clock is 3.5 hours slow.
you would think Fitbit would be able to put out a statement saying @@we know we screwed something up, but we’re working on fixing it”. But it’s just crickets chirping from them.
08-10-2020 15:25
08-10-2020 15:25
Mmereth,
I had delayed the last update for a long time and finally applied it hoping that they had fixed the problems. I was wrong.
Did you try calling them? In the past they have done free replacements sometimes after an update bricks the Versa II.
