06-08-2018
11:01
17:10
EdsonFitbit
06-08-2018
11:01
17:10
EdsonFitbit
Does the Blaze have just as many problems as the Versa? My Versa will not sync, cannot quick reply, and I had to go buy a new charger because that didn't work at one point. Maybe the Blaze is better option, my Versa won't do anything that the Blaze can't and I bet the Blaze will sync.
Moderator edit: added label
06-11-2018
05:48
09:59
06-11-2018
05:48
09:59
A warm welcome to the Fourms @AsiaC.
I am sorry to hear about the issues you are experiencing with your Versa. Regarding your inquiry, I recommend checking this page, where you will be able to compare all Fitbit products.
Now about the problems you are having, check the following:
I hope this helps, let me know the outcome. ![]()
06-11-2018
05:48
09:59
06-11-2018
05:48
09:59
06-14-2018 14:31
06-14-2018 14:31
I tried some of most of your suggestions and my Versa is functioning properly! I'm not sure which worked, but I haven't had any problems in the last few days. Thank you!!!
06-15-2018
04:24
09:59
06-15-2018
04:24
09:59
