04-22-2018 20:18
04-22-2018 20:18
How to enlarge font size on incoming texts. I can’t even see it with my glasses on.
thanks
04-23-2018 07:40
04-23-2018 07:40
There is no provision to increase Font size.
04-22-2018 21:29
04-22-2018 21:29
I would like at least the option to make it bigger. Without my glasses on, it's nearly unreadable.
04-23-2018 07:40
04-23-2018 07:40
12-28-2018 10:29
12-28-2018 10:29
The notification font size makes the notification on versa useless. I have to pull out my phone for reading notification. Fix it.
@Lwilliams114 wrote:How to enlarge font size on incoming texts. I can’t even see it with my glasses on.
thanks
12-23-2019 07:47
12-23-2019 07:47
I agree need larger font size also time is very large but I have time seeing steps because it is so small
12-23-2019 07:53
12-23-2019 07:53
Regina, choose another clock face from the hundreds that are available.
12-23-2019 09:03
12-23-2019 09:03
You apparently need glasses. If you already wear glasses, you need a new prescription. I am 70 years old and can read the text fine with my glasses.
06-09-2020 12:27
06-09-2020 12:27
I use readers. I would not use then to jog, or lift weights. I also don't wear then to bed. Short of growing longer arms, the best fix would be to be able to adjust the font.
I wonder if there is any work being done to make that available?
11-09-2020 04:22
11-09-2020 04:22
I don't want to wear reading glasses while I'm working out. I can see the clock just fine, can't see text messages or steps.
02-24-2021 17:40
02-24-2021 17:40
I agree. I can see the clock but can't read anything else because font is too small. It's very frustrating.
02-25-2021 09:33
02-25-2021 09:33
@DVOO Thanks for stopping by!
Thank you for your feedback. Currently this isn't available but you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Hope this helps.
