My text messages stopped working on my versa. they worked for 2 months then they just stopped working. I have a iphone 7 plus. How do i fix this problem? Thank you in advance
Best Answer@Valentilm blah blah because Apple change Bluetooth settings without notifying the devs like it's normally done. This will have to get addresses with the app update. For now, please try this:
Hi, notifications on a Versa using an iPhone are a known issue. In principle Fitbit supports only notifications from Android on the Versa. The only thing you can do to solve it, cause it worked before, is restarting your Phone once and the Versa several times in a row by pressing and holding the left and right lower buttons together untill the Fitbit logo appears and release the buttons. Do not know for sure that this will work but it's worth a try.
Best Answer@SunsetRunner warm welcome to the forum! I'm sorry to hear your Versa decided to misbehave. It is true that it's been a bit bumpy ride since the recent iOS update, which you have noticed. I myself have iPhone 7 Plus as well and Fitbit fully supports notifications on iOS excluding quick replies that is. As far as I know Fitbit is working on ironing out the bugs that appeared after iOS update. For now, perhaps you could try this to restore the Bluetooth connectivity and notifications:
If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled.
Best AnswerLooks like the latest 13.1.1 has disrupted text and call notifications. Kinda sucks since that is a great feature! Repairing, syncing and “blah blah” didn’t fix it. Hope Fitbit updates soon so this works again.
Ive done this and im still not receiving my notifications. I have a Iphone and since the big update 2 days ago im not receiving notifications
Best Answer@SunsetRunner It's all due to iOS13 update. Gotta wait for the fix. Have you tried what I discribed here? It's not bulletproof but seems to work for some.
Best AnswerI have desperately tried to resolve this issue since the latest updates (even the bug fix one) just a few days ago.. I can receive every other possible notification on my Versa (first one) - calls, messaged, app notifications etc - yet I can no longer receive texts on my versa - I HAVE TRIED EVERYTHING POSSIBLE - all of your suggestions here and more - yet it is still not displaying text message notifications!!!! WHYYYYYYY 😭😭😭
Best AnswerI share the same frustration as you.
I don’t receive text messages on my versa anymore!!
@Fitbit - Is this a know issue with the latest update? Is there a fix coming up soon?
Best AnswerThank you but that’s be fine and no go.. I’ve tried everything possible - wasted 3-4 hours yesterday 😩
