01-29-2022 16:09
01-29-2022 16:09
Hi, I have a Fitbit Versa 2 that I would like to use to text. I don't have a phone, but I have an Apple Ipad that I use to run my Fitbit. I have had my Versa 2 for quite a while now. My question is, how can I text or receive text notifications with my Versa 2 without using a phone? Is there any app that is compatible with both my Versa 2 and my Apple Ipad?
Thanks, OliveLove
01-30-2022 06:43
01-30-2022 06:43
I'm sorry @OliveLove, but because you have an iPad (Apple product), texting is not available. It's not available to any Apple users at this time. However, you can still receive notifications of a text. Go into your Fitbit app and tap your picture. You should see a picture of your Versa 2. Tap it and you will be taken to the Device Settings. From there, select "Notifications" and then "Text Notifications". Find your iPad and select it. From there, sync your Versa 2 and you should be all set.
one cruise ship at a time!
Best Answer01-30-2022 06:41
01-30-2022 06:41
At least with Android you can use Messenger to get text notifications. In the Fitbit app (Android anyway, may be the same for iPhone) tap your profile icon at the top left of the Dashboard, then tap on your Versa 2, then tap Notifications (under General), then Text Messages. If you have Messenger installed you should be able to select it as Default Messaging App.
Best Answer01-30-2022 06:43
01-30-2022 06:43
