05-21-2021
18:25
10:46
05-21-2021
18:25
10:46
My Microphone stopped working a day after I got it, the Microphone is enabled and everything. Currently factory resetting but I wouldn't be surprised if it still doesn't work.
Update, factory reset made my watch glitch out and still no microphone.
Moderator Edit: Merged posts
05-22-2021 10:50 - edited 10-19-2023 10:00
Hi there, @Astrolog. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please know that he microphone in your watch only turns on when you’re using a feature that requires your voice, such as a voice assistant. The microphone turns off when the voice assistant responds, when you close the voice assistant, or when your watch’s screen turns off.
On the other hand, if you recently went swimming or got your watch wet, there might be water in the microphone. Wait a few minutes for the microphone to dry, then try again to use your voice assistant.
Best Answer05-22-2021 10:50 - edited 10-19-2023 10:00
