Time
Can you change the Fitbit face screen to show time as 1:56 instead of
01
56
2 REPLIES 2
That probably depends on which clock face you are using.  If you are using a clock face that has hours and minutes above and below each other, there is probably other info beside them.  Look for a different clock face that shows the time the way you want it.
See How do I change the clock face on my Fitbit device?
Thank you. Now my Fitbit says to update to change clock faces. But it keeps
searching for my WiFi. Help!
