02-20-2020 13:20
02-20-2020 13:20
2 days ago I noticed that my touch screen isn't working anymore. I can't turn off or set alarms or really anything that involves having to use the touch screen. Any advice? It's only 3 months old.
02-20-2020 15:28
02-20-2020 15:28
Hi @chrisrun20 Try restarting it several times and see if that gets it working again. If it doesnt then do a button factory reset and then set up your Versa 2 again. If that doesnt get it going then you will need to contact Support
BUTTON FACTORY RESET FOR VERSA 2
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
