09-25-2018 16:54
09-25-2018 16:54
Been trying to transfer music from computer to Versa. Versa cannot connect to our Wifi so I was wondering if there is some way to transfer music across Bluetooth or some other way?
09-25-2018 20:24
09-25-2018 20:24
No, unfortunately it has to be via wifi.
Helen | Western Australia
09-26-2018 04:06
09-26-2018 04:06
Mine finally transferred. . however, now the versa cant find my headphones. .so the music is useless
Best Answer09-26-2018 10:34
09-26-2018 10:34
Hey @Edski0000, welcome aboard! In order to transfer your music form your computer to your Versa, you need to do that using a Wi-Fi Network, as @NellyG. said. It can;t be via Bluetooth. Please take a look at the instructions in this help article: How do I listen to music and podcasts on my Fitbit watch? And follow the instructions there to complete the transfer.
@painterfam, Sounds good that your music was transferred. If your headphones won't connect, I suggest you to restart your Versa and ten try to pair them again.
Let me know how it goes guys!
Best Answer09-26-2018 12:47
09-26-2018 12:47
When I try to set up the Fitbit Connect app on my Mac, I get stuck when I try to choose my Versa device. The setup screen with device options does not list the Versa as an option, and states (in small text) that I should use my mobile app to connect to a Versa...?
Best Answer09-28-2018 06:09 - edited 09-28-2018 06:46
Hey @DrHall, let me give you a warm welcome to the Community! Let me tell you that it is not possible to connect your Versa with the Fitbit connect program. In the meantime, if you have a compatible device, download the Fitbit app on it and follow the instructions in this help article: How do I set up my Fitbit device? To pair your watch.
Let me know how it goes!
