11-26-2018
12:15
08:55
MarcoGFitbit
11-26-2018
12:15
08:55
MarcoGFitbit
My Versa is rubbish. I have had it for 2 months now and I do not receive notifications. I keep emailing support and they keep sending the same reply, they are working on the problem and thank you for your patience. Not good enough. Meanwhile they continue to sell this rubbish
@TeddyG I am sorry to hear that you're having problems with your Versa. Is there a question coming or is it a mere statement of fact? Sorry, but it would really help if you shared some basic info - phone model, OS, Versa's firmware version, Fitbit mobile app version. Perhaps we can help.
@TeddyG Sorry for my reply, Teddy. I had to get back home to check my iPhone 7 settings. I use it as a back-up phone as I'm primarily on Droid. I've been seeing quite a few comments on the forum from iPhone users who are on iOS 12.1... I never updated and am still running 12.01. My question to you would be- did your Versa worked with earlier iOS version? Also, could you please explain what you mean by reinstalling Versa? Do you mean wiping it (restoring to factory defaults = factory reset)?
@TeddyG I must say this is weird. What I would do (I know it's frustrating and kinda shooting blind), but I would wipe Versa (go to Settings on your tracker>About>Factory Reset). I am recommending this because the Factory Reset will force Versa to download the newest firmware (.19). Before factory reset, please delete Versa from your account (ugh! I know i know), remove it from paired devices on your phone, uninstall fitbit app, reboot your phone and install the app. Once Versa shows its set me up screen (after factory reset), open fitbit app, log in and follow the instructions. I would not add wifi though. I would perform the whole update via Bluetooth, which might take loooong (2 hours). Report back.
Best Answer@TeddyG I am so sorry to hear that. I honestly feel we have tried everything. @JuanJoFitbit @MarcoGFitbit @AlejandraFitbit, you've always been so great helping us resolving issues, could you please take a look at Teddy's ticket? Thank you so much for your hard work! And thank you @TeddyG for your patience.
Hello @TeddyG, I hope you're doing well, it's nice to see you around the Fitbit Community. It's great to see you too @Marrrmaduke, thanks for bringing this situation to our attention. ![]()
@TeddyG, I appreciate your participation in the Forums and for sharing your experience with us. I appreciate you have already tried some troubleshooting steps and have updated the firmware on your Versa already. At this moment, I would like to suggest you to go to your phone Settings > Notifications > Fitbit and make sure the following is enabled:
If this is already enabled, disable everything, then restart your phone and enable everything back.
I appreciate your patience and understanding, give these steps a try and let us know the outcome!
Best Answer@TeddyG Yay! I am so happy! Just out of curiosity, which version of Versa's firmware did you get? @MarcoGFitbit Thank you so much for help! You're the best.
Hello @TeddyG and @Marrrmaduke, I hope you're doing well, it's nice to see you back. ![]()
@TeddyG, I appreciate you have come back and let us know your issue has now been resolved and you're able to receive Notifications, I'm very glad!
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer@TeddyG Oh no... I am truly sorry to hear that. You know at this point, it does not hurt to exchange it. What really boggles me is why it stops working. It works then puff... I have had a quite a few fitbit devices and I remember I had similar issues with my Charge HR. It was working then it stopped syncing entirely. I had to perform magic tricks etc, but then at some point Fitbit ironed out all the bugs and the device again worked as designed. But, it's neither here nor there. You should be able to enjoy it that's why I would give an exchange a shot. One more thing that comes to my mind is... other bluetooth devices. You see Versa is possessive... Very jealous little thang. I noticed that if I had my bose earbuds paired (and God forbid) connected to my phone, Versa would stop syncing/connecting. So, if you have anything else paired with your bluetooth I would remove it and see if that helps. Yes, I know the BT connection should be more stable... Another thing, does a quick unpairing from Bluetooth, toggling it OFF/ON, and forcing sync (and pairing) from within the app works? I still have to perform the abbreviated version of the procedure from time to time.
Best AnswerI'm having the same problem with my Versa. I'm following the steps in this thread to factory reset and try again. I am on Android, not iPhone though. So, it doesn't relegated to one set of software.
Best Answer@TeddyG It unfortunately affects both iOS and Android. Perhaps even more Android as it is so fragmented.
@tesser88 One more tip I can share with you as you're on Android is to downgrade to Fitbit mobile app version 2.74.2. I find it to be the most stable and working quite well with the abbreviated version of the procedure.
Good luck, guys.
