Unable to remove Alarm on Versa 2
ANSWERED
I purchased a fit bit versa 2. A week later I set an alarm to wake up. I then went to remove the alarm and no matter what I do I can not remove it. I have removed the alarm from my fit bit and synced it with no success. I removed the fit bit from my phone with no success. I have also performed a factory reset and the alarm is still going off at 6:15am every morning. Has anyone had success with removing it or is it a fault in my watch and need replacing?
1 BEST ANSWER
Accepted Solutions
I notice you have the Versa 2. Could it be that you have an alarm set up in Alexa? These are separate from the standard alarms.
3 REPLIES 3
Thank you so much! I hope this works. I spoke to Alexa and it asked if I wanted to delete the alarm so I said yes. I didn’t realise I had actually set one through Alexa, must have done it when I first got it, playing around. Let’s see tomorrow morning if it lets me sleep in!
Mine is set for 239 AM, I've never set this alarm.. I need my sleep.  Did it let you sleep?  Mine is not on ALEXA.
