I have a 15 day old Versa which i did setup on my Galaxy Note 9.It worked for few days.
I had to format the phone and this time before setting up i formatted the Versa as well.
Now when i try to setup Versa after i punch in the 4 digits from the watch to the APP it says "Connecting" and after few seconds the message disappears and i see the screen "Account" screen which has the option "Set up a Device"
All i see is the Fitbit Logo on the watch now and if i have to try to set it up again i have to restart the watch and then follow the same procedure.
I have tried other handsets as well and its still the same.
Did anyone face this problem?
Hi, try to setup your Versa using WiFi instead of BT. To do that, put your Versa in the charger and connect it to your computer. It's best to do that also with you phone. Go into the Fitbit app and go to WiFi settings and press it. You will see the name of your network and right next to it the WiFi icon in white. Press the icon and Fitbit will start connecting to your network. Once that's done, the icon turns to blue and says connected. to check whether your Versa is also connected, go to the settings of your Versa and press it, scroll down to Device Info and press that too. If you see there an IP address then your Versa is connected. now go to Fitbit app again and press "add device" and choose, of course, Versa. Good luck.
Appreciate your reply brother.
I am little confused.
Where will i find the Wifi settings?
I cant seem to find the wifi settings in the Fitbit App.
Also are you talking about the Fitbit app on the android phone or on the computer?
Best AnswerI'm talking about the Fitbit app on your android device. In the dashboard of your Fitbit app, press the watch icon on top of the screen on the right side and you will see the page with the Clock and App tiles. Scroll down untill you see WiFi settings and press it and proceed as explained in my former post.
That's where the problem is.
I cant see the device in the App.
That's why i am trying to set it up but it doesn't seem to proceed.
In the Fitbit app on the dashboard screen on the top right i dont see Versa listed.
Any suggestions?
Best AnswerIf you have followed my suggestions in my first post, I said that once the WiFi connection is established, you will need to go to your Fitbit app on your Android device and to be precise, press the account icon (looks like a credit card) on top of the screen on the right side and you will see a new page with the possibility under "devices" to add a device, press that and choose Versa. Good luck!!
Best AnswerGood News is that i logged in to an old fitbit account which had this versa showing up somehow.
I was even able to upgrade the firmware and the watch is alive now
But the problem is that its not syncing
Last sync it shows few days back
When i click on the Sync Now button it comes up with an Exclamation mark and there is no message showing up
Should i remove this versa from this account and then map it again?
Best AnswerNo, first try restarting the Versa 4-5 times in a rowby pressing the left and right lower buttons together untill the Fitbit logo appears and release the buttons. If that does not solve the syncing problem, try this:
1. First of all do not remove or unpair your Versa from the Fitbit app on your phone.
2. Deinstall the Fitbit app
3. Restart your phone and wait for a few a secs
4. Reinstall the Fitbit app and, of course, enable BT
5. Sync your Versa with the Fitbit app on your phone and see if that has solved your problem.
Good luck!!
Hello @Preet03, welcome to the Fitbit Community, it's great to have you on board. Thanks for all your help @SunsetRunner. ![]()
@Preet03 I appreciate your participation in the Forums and for sharing your experience with us. I would like to thank you for letting us know you were able to set up your Versa. Now, if you're having trouble syncing it and you have already tried the troubleshooting steps provided by @SunsetRunner I would like to suggest you the following:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
