@Fiko84 You mean your Versa is locked (it asks for the code) and you removed it from your Fitbit account (Fitbit mobile app)? Unfortunately, you need to either perform a 3-button factory reset or contact Customer Support. Please try the following:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
