06-05-2020 07:40 - edited 06-05-2020 10:06
06-05-2020 09:49
06-05-2020 09:49
I just found that my iPadOS needed an update. It’s now 13.05.01
I tried the Fitbit app page again, but no difference.
It still says to update my Versa2, however the app still won’t find my Versa2.
Does anyone know what I should do next?
Ive looked around for similar problems however there doesn’t seem to be many around that has had problems with Versa2 unable to be found after a update attempt.
Best Answer06-05-2020 10:03
06-05-2020 10:03
I turned off and on Bluetooth in my iPads settings and tried to search for Versa2, but that did not work either.
Best Answer06-05-2020 10:18
06-05-2020 10:18
After updating my iPad and pushing off and on Bluetooth in my iPads settings I went back to fitbit app and to my surprise it was syncing and the part asking to update was gone!
I hope that means the Versa2 has updated.
MY PROBLEM IS SOLVED.
I am not sure what fixed it, but I’m sure glad the Versa2 is connecting with the app again!
Best Answer06-05-2020 10:21
06-05-2020 10:21
