05-25-2019 09:05
05-25-2019 09:05
Hi Everyone,
Just got my Versa, I was just wondering if it will be on to take to Tenerife... we do alot of walking and I will be in the pool - I want to count the exercise I will do but I was wondering about max working temps. Will the versa be ok in 30+ Cel??
Also for security is it best to take it off as you go through the scanners? I’m presuming theres no reason I can’t wear it on the plane?
Perhaps a silly Q so thank you for answering!!
05-25-2019 10:22
05-25-2019 10:22
@Linzi89 The Versa specs give a maximum operating temperature of 140 F = 60 C. You're good. I have USA TSA Pre check, so I don't have to take it off to go through scanners. No problems. You can wear it on the plane. You won't be able to sync with your phone in airplane mode.
Laurie | Maryland
05-25-2019 10:08
05-25-2019 10:08
Hi! I recently got a Versa. I live in Qatar and I while I haven't been working out outdoors since I got the Versa (it's too hot), none of my Fitbits have ever overheated previously. I think you'll overheat before your device does.
For security, I asked if I should take it off in Canada and they said "It's up to you." I didn't ask in Heathrow, and they didn't have a problem with it. If you're worried you might have to take it off, and don't want to get it stolen, just tuck it in your carry on when you get to security, but if they didn't mind at Heathrow, I think it's OK.
I'm going to Tokyo myself next week, and can't wait to get a zillion steps every day! Bon voyage!
05-25-2019 10:22
05-25-2019 10:22
Laurie | Maryland
05-25-2019 11:00
05-25-2019 11:00
Fab! Thank you! Have a wonderful trip 🙂
05-25-2019 11:01
05-25-2019 11:01
Thank you for the info! Much appreciated!
