03-15-2023
17:31
13:49
JuanFitbit
03-15-2023
17:31
13:49
JuanFitbit
Hi Team,
When i tried to connect to WIfi to VERSA 2, it is getting connected after 30 seconds, it is getting disconnected without my knowledge. i tried all the ways, like restarting the VERSA 2 and restarting the Android Mobile. But still No Use . Please help to overcome with this issue.
ANDROID DEVICE : REALME 8 5G
VERSA 2 VERSION : 35.72.1.23.
if i need to update the version . please guide me to do
Reagrds,
Eswar
Moderator edit: updated subject for clarity - format
03-19-2023 06:34
03-19-2023 06:34
03-15-2023
18:54
09:51
03-15-2023
18:54
09:51
@Robin054 , A warm welcome to the Community! Thank you for your information and efforts.
Have you tried connecting the Wifi, with the Versa 2 plugged and charging?
Sometime depending on the battery level, the WIFI gets disconnected to save the battery as it's connection consumes it faster.
More tips can be found here: Why won't my Fitbit watch connect to Wi-Fi?
03-15-2023 20:41
03-15-2023 20:41
Hi @JuanFitbit ,
Thanks for your Answer, Yeah i tried that as well. Even then I am loosing the wifi connectivity. After a min. Can you tell me any other ways should I try.
Best Regards,
Robin
03-15-2023 21:35
03-15-2023 21:35
mine has been disconnecting multiple times a day every day for the last week or so
03-15-2023 22:41
03-15-2023 22:41
Hi @Robin054 @Jessicasquishy - why are you trying to be permanently connected to WiFi?
WiFi uses a lot of battery so it is normal for the watch to automatically disconnect when it is not being used.
03-19-2023 05:16
03-19-2023 05:16
Hi all,
The problem still exists, when I wanted to download the gallery, or if I wanted to connect to Saavn playlists, it requires wifi, so by the time I connect to wifi. It is getting connected, if I come out of the app or syncing in the app. The wifi is getting disconnected. So how to download the alls and how to connect wifi. Please help me
Thanks in advance.
Best regards,
Robin
03-19-2023 05:22
03-19-2023 06:25
03-19-2023 06:25
Hi,
This is the observation when i tried to open the gallery option. The fitbit versa 2 is connected with Bluetooth. Even though I am unable to open the gallery. What should i do now.
Best Regards,
Robin.
03-19-2023 06:29
03-19-2023 06:29
@Robin054 - even though the phone is connected, see No internet connection
03-19-2023 06:31
03-19-2023 06:31
Hi,
Yes, it is displayed like that. So, what should I do now. Please help me.
Best regards,
Robin
03-19-2023 06:34
03-19-2023 06:40
03-19-2023 06:40
Hi,
Thanks buddy. It's working with this method.
Best Regards,
Robin
