06-16-2020
04:07
20:02
EstuardoFitbit
06-16-2020
04:07
20:02
EstuardoFitbit
My versa 2 has some cloudy sort of damage on the back and looks a bit “sanded” or ”cloudy” (where the sensor and charging pin is) and I don’t know what has caused it. I’m afraid it may affect the accuracy of the recorded data and if possible will like to get this fixed, please help!!
06-16-2020 06:15
06-16-2020 06:15
Could it be dried hand lotion? Does it wash off?
Best Answer06-16-2020 06:26
06-16-2020 06:26
Best Answer06-16-2020 06:28
06-16-2020 06:28
No it does not wash off and doesn’t seem to be dried lotion either, that’s why it’s getting me worried
Best Answer08-15-2020 18:36
08-15-2020 18:36
I have exactly the same issue and it now bothers my wrist. I tried cleaning it and it does nothing to change the damage. I have no idea what it is and have never worn it in water.
Did anyone from Fitbit fix it for you or provide a solution?
Best Answer08-15-2020 21:50
08-15-2020 21:50
Best Answer08-16-2020 03:17
08-16-2020 03:17
Thanks. I'm going to try to contact them.
