05-02-2022 09:51
05-02-2022 09:51
My Versa 2 battery life is dropping dramatically. I connected my headphones via Bluetooth for a race yesterday, and my battery life tanked to 25% in 65 minutes. I disconnected the devices, changed to 100% this morning but within 2 hours I'm back down to 62%. I throw it on the charger each morning when I shower, and my typical battery life after a days use is 85%. I'm not connected to anything, and I haven't been checking the time or even been active as I've just been sitting at my desk. I don't have any fancy clock faces, just standard Fitbit face. Any advice?
05-02-2022 12:53
05-02-2022 12:53
Hello @lputich
I would try restarting your Versa 2 to see if that resolves the issue. You won’t lose any data doing so. Just hold the button on the side down until you see the Fitbit Logo then release the button.
I hope this provides you with a solution. Please let me know. 😃 Happy Stepping!
Best Answer05-12-2022 18:14
05-12-2022 18:14
Unfortunately FitBit won't acknowledge there's an issue. It's likely an issue with the latest firmware. If you are under warranty try to get a replacement. Same thing happened with my wife's Fitbit as well as others in this forum. Time to consider another brand.
