02-11-2020 07:54 - last edited on 07-09-2020 13:41 by LiliyaFitbit
My clock face stays on all the time. Before it only came on when I moved my wrist and two clock faces appear. When I move my wrist my chosen clock face appears. That is then replaced by another clock face that stays on until I move my wrist. Can you advise how I can remove this second clock face.
Thanks
02-11-2020 13:18
02-11-2020 13:18
I suggest you check to see if your always on display has been set to on. Swipe left till you find the settings icon. tap that and scroll down to the always on tile. tap that and check to make sure this is off to turn off the second clock face.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
02-11-2020 13:18
02-11-2020 13:18
02-11-2020 14:13 - last edited on 07-09-2020 13:41 by LiliyaFitbit
All sorted.
Thank you
Regards
