01-07-2023
05:08
17:59
LucioFitbit
01-07-2023
05:08
17:59
LucioFitbit
My fitbit has been stuck on the stopwatch screen. I cannot go back with swipe.
The soft reset doesn't work and i cannot get to the hard reset. Also trying to change the clock doesnt work as it remises to change. Please help..
01-08-2023
18:07
09:09
01-08-2023
18:07
09:09
Hi there @Sanne_JD. Welcome to Community Forums.
Thank you for the troubleshooting steps performed and the feedback. I'd recommend you follow these steps to restart your device.
You can try to change your clock face, if this fixes the issue, you can change it back to the original clock face. If you are using a third-party clock face, please switch to a Fitbit clock face and try the troubleshooting again.
